Missing values in Slaying the Dragon
superoddesuperodde Posts: 2
Hi,
Some values are missing from my text-boxes. So far I have been able to guess correct, but for Adjusting X Translation on Camera I'm stuck :(
Someone knows why I don't get the values? And what should the value be?
Thanks!
1092 x 406 - 69K
    No idea why you are not seeing it. Have you tried moving the Window by drag and drop?
    X Translate to 212
    Y Translate to 133
    X Rotate to 1
    Z Rotate to 4
    I think the text is wring on the second box, it refers to X translate as well at one point, but it does say Y in the label I think..
    Hope that helps?
  • superoddesuperodde Posts: 2
    Thanks! I sure tried to move around, etc...
    It must be due to active style. When I changed from 'Dark Side' to 'Main Street' I was able to see the values.
    I would call it a bug ;)
    762 x 520 - 65K
    Most peculiar, I use Darkside, and it works for me:)
    Glad it's working now, I think these lessons can be very useful.
    Strange indeed!
    And now the error is back. :( With both styles....
    Strange and annoying. Some parameters are quite easy to predict, but others are impossible.
    For others having trouble I found that:
    - Focal Distance on camera should be adjusted from 450 to 332
    - zTranslate of our hero to -69
    - Y Rotate of our hero to -53
    Some others also had to be guessed, but I was not clever enough to make notes of the values.
    Anyhow, I'm finally done with the dragon :)
  • edited December 1969
    Sightly off the subject, but does that "Slaying the Dragon' bundle actually include a poseable Dragon model..?
    Many thanks.
  • Scott LivingstonScott Livingston Posts: 4,352
    Many thanks.
    The dragon is included with the free Genesis Starter Essentials package. If you don't have that, you can get it via the Install Manager, or search your Product Library for "Starter Essentials."
    Many thanks! I thought I had that installed, but I guess not. Will check it out now! Thanks again. :)
