Vyusur body fur missing one
marblemarble Posts: 7,500
edited September 2021 in The Commons
Just bought this product: Body Fur for Genesis 8 Males | Daz 3D and am amazed and disappointed to find that it is missing the only two essentials that I was hoping for: armpit and pubic (see below). Seriously, how many hairy males are missing those two? The promo pictures at least suggest the stomach hair continues down but no - there is a cut off beyond which the gent is bald.
[EDIT] I just checked the product description and it says, I quote:
Between Chest, Body, Belly, Arm, Leg, and Shin Fur in astounding materials, you have everything you need to make your very hairy character.
 Everything I need? I don't think so. You might argue that those areas are not specifically mentioned  but then Body, Belly, Arm ought to include the missing bits, right?
*** Please see the response from Vyusur below ***
Post edited by marble on
  • There's a fair assortment of pubic-hair freebies:  some are worth every penny they're sold for.  But good, well-rigged armpit hair is and has always been sorely lacking, despite the fact that far more renders need it than require what's below the belt.
  • marblemarble Posts: 7,500
    I've just checked and it seems that the G3M product from Redz (Oh My Body Hair) does work on G8M so I really didn't need to buy the G8M Body Fur at all.
    Ah well, I should have tried that first.
  • VyusurVyusur Posts: 2,235
    I'm sorry for your disappointment, but I didn't write these lines. They were added in the process of QA. My original submitted text is only two top lines.
    And the product contains the pubic hair. You can see some examples of them on my promos at the known place. I couldn't show this kind of content here due to nudity restrictions.
    Armpits hair is the only missing set in my product that you mentioned.
    Post edited by Vyusur on
    Wait - it does contain pubic hair? Ahh, so it does. My sincere apologies. I had clicked on the first "Belly Hair" option and assumed the others would stop short too. Again, my bad assumption.
    663 x 553 - 34K
    Some more examples.
    1000 x 1000 - 1M
    1000 x 1000 - 1M
    1000 x 1000 - 2M
    1000 x 1000 - 2M
    Vyusur said:
    Some more examples.
    Yes, I discovered my mistake as I mentioned above. Again, I'm sorry for the hasty assumption.
    edited October 2021
    Vyusur said:
    Some more examples.
    Just one final comment on the PH after trying with some thrid-party (Meipe) anatomy attached (I don't have the DAZ anatomy). The hair on options 2 and 3 does not reach down far enough so there is a significant bald area where the geograft is joined. Options 4 & 5 are a little closer to the mark but those optons are far too hairy higher up for my use. I have worked with other products (some freebies) on other generations and they include morphs which allow for adjustments (movements, thin or thick hair, curl, clumping, etc.). I can't find any adjustments to your sets, however.
    EDIT: Nvm, easy enought to make a morph in Blender.
  • vonHobovonHobo Posts: 1,715
    edited October 2021
    I have this product by Vyusur and it is really good. Easy to work with too.
    It's a bit more realistic too, than some of the other body hair products.
    I didn't have the problems that you mentioned, but maybe I'm not using it the same way.
    Post edited by vonHobo on
    Not sure I understand what you are saying here. I did not criticise the realism or the question of whether it is easy to work with (just click and it loads - very easy).
    My point was that there is no armpit hair and that the pubic hair options do not have adjustments to change the shape or position so that the fit matches the geografted anatomy. Those are just observations of what is obvious, not something that works for some and not for others. As I said, I managed to adjust the fit myself by exporting to Blender to create a morph. To be honest, I can't imagine a use for pubic hair without the corresponding anatomy.
  • nemesis10nemesis10 Posts: 4,053
    "To be honest, I can't imagine a use for pubic hair without the corresponding anatomy."  Some outfits have a morph to unbutton pants buttons....
    OK, true. Still have to wonder why unbutton the pants if there's nothing but hair there? :)
    edited October 2021
    It is the difference between an R rated movie and an X rated movie?  Think of the difference between a playful tease and "hey, want to see my unit?'.
    Post edited by nemesis10 on
