How to apply the citizen texture in G1M without M5?
jorge dorlandojorge dorlando Posts: 1,159
Ok, I bought this item these days and,
http://www.daz3d.com/citizenx
It says compatible with Genesis,
but also says, requires M5
I have no m5, no.
I apply the direct texture, in Genesis 1
but it is with some gray areas, which I think is the problem with UV
where I find a uv set m5 to geneis 1?
if it is the same problem ...
thank you
    I have no m5, no.
    thank you
    You would either have to buy Michael 5 or use the character with G2M which has the M5 UV built in. There are some tutorials to copy the morph over to G2M using the transfer tool if you don't have Genx.
  • jorge dorlandojorge dorlando Posts: 1,159
    edited February 2015
    I have no m5, no.
    thank you
    ok, thank you but the morphs works perfect in G1m.
    the problem is only the texture
    there is a genesis character that comes included in the package CitizenX ... and even this carries with white areas in texture ..
    Image removed
    If you do not wish to move the morph to G2M, then you will have to buy M5. I would check the store for sales. Or if you purchased the character within the 30-day window you could request a refund.
