How To Use Other UVs on 8.1 figures?
What is the method or product for using previous generation's UVs on 8.1 figures?
  • The Blurst of TimesThe Blurst of Times Posts: 2,410
    edited September 2021
    Double click on the materials?
    DS knows how to apply Genesis 8 materials onto 8.1 without an issue.
    It won't be the new PBR shader, but that's a separate topic.
    Since Genesis 3 has the same layout, the Base Female UV will work in a similar way. (i.e. similar to applying Genesis 3 skins on Genesis 8.)
    Those weird character-specific UVs need the converter products that work with Genesis 8. You might be able to do some manual make-up work with those figures that got an 8.1 update, though. I forget if it worked for me or not when I was playing with Kalea 7 for 8.1 in the current starter essentials...
    Genesis 2 and earlier? Uhhhh... I'm not sure what's possible.
    Post edited by The Blurst of Times on
  • LeanaLeana Posts: 13,617
    The same as with Genesis 8 figures, you can use G3 textures directly and you need the legacy UVs products for earlier figures.
