Any horns like this?
gsil247gsil247 Posts: 231
edited September 2021 in The Commons
I'm trying to find horns that are shapped/posed like this as I'm trying to create this character in Daz. All I found are ones that go up or to the side. I guess no one ever thought to pu them facing this direction.
Thank you for any help.
720 x 720 - 77K
Post edited by gsil247 on
  • Have you tried places like sketchfab, cgtrader, turbosquid, etc..? All will certainly be available as obj, and you could transform them and parent them to the head bone...
  • Horned Fantasy Headdress by PhilW can look somewhat like that if you hide everything but the horns. You can use the sliders to get the basic shape and then pose the individual bones to get it closer to what you want. Here's a quick test on G8.1 Base Female with Super Sleeky Hair (because that's what I had on hand), but there are other hairs that would probably work better for this character.
    1600 x 2000 - 2M
  • gsil247gsil247 Posts: 231
    How did you do this? Can you explain to me like I'm an idiot because I kinda am? This close exactly like what I would want. Thank you for this.
  • Did you check these out:
    https://www.daz3d.com/fantasy-horns-for-genesis-8-female-volume-1
    https://www.daz3d.com/arcane-enchantress-horns-for-genesis-8-female
    There are some that turn inward; but I'm not sure if you could rotate them downward to suit or not.
    Here's a scene subset that loads the horns with the settings I used, with the non-horn parts hidden. Naturally, you have to have the PhilW product installed for the file to work, and some adjustments may be necessary.
    The sliders in the Actor section of the Parameters tab control the overall shape (thickness, length, etc.) of the horns. If you need to fine-tune the way they bend, they have 16 bones each that can be posed using the General --> Transforms section of the Parameters tab. Your workspace may be set up differently from mine, but the attached images might point you in the right direction.
    Also, I got better results parenting the item to the character's head instead of using the Fit To dialogue. I'm not sure if I've actually explained anything at all, but I hope this helps.
    3584 x 2240 - 1M
    3584 x 2240 - 1M
