Facegen help required
Hi, I am trying to do a very basic facegen export morph for genesis using their own plugin. I grabbed the Alyssa Milano example from http://www.relativitybook.com/CoolStuff/facebank.html as I think it is one of the better ones on there and ran the facegen exporter over it, then I loaded in a Basic Female and applied the head morph that was generated, but the resulting head shape doesn't look nearly as good as the facegen preview itself. I have tried turning the basic female head morph on and off but it just doesn't look right and applying the exported textures doesn't seem to help much either. Can anyone advise on how to get the best results?
Cheers
182 x 327 - 110K
Never mind, I found that the results are much better if you export the head as obj and work with that rather than the genesis morph
