Settings for HD Characters
inquireinquire Posts: 2,460
Let's says I have Lee 6 HD. In Parameters, it's at High Resolution, the HD is at 1, the Subdivision is also at 1. I've been told that I don't have to change the Subdivision level if I want to render in DAZ|Studio. When I render, D|S will apply the HD automatically. Is that true?
I've also been told to change the Subdivision level to 3 if I want to render in Lux.That seems to be the case.
But, how about HD in D|S. Can I just leave the Subdivison at 1?
  • Richard HaseltineRichard Haseltine Posts: 111,315
    Yes, 3Delight will always render to the SubD level required by your render settings regardless of the viewport setting (SubD does need to be on, however - setting the mesh resolution to Base will turn it off entirely in 3Delight). Things like LuxRender via either of the bridges, or Ocatane via its plug-in, will use the viewport SubD setting as far as I know so for those (or for export to OBJ for use in another application) you would need to turn the setting up to 3.
  • inquireinquire Posts: 2,460
    OK, thank you for the clarification.
