A question about Skin Builder 8 for Genesis 8
How do I disable it? No matter what file I upload, it never goes away. Now all my scenes give off static whenever I move around. What happened was I made a mistake and clicked on the icon before selecting a character in the scene itself.
Link: https://www.daz3d.com/skin-builder-8-for-genesis-8-females
Post edited by lou618_2b45855fe7 on
Skin Builder is just a script, when you aren't running it it doesn't have any effect.
Right, but even when I reload Daz with a fresh scene its still active, with static showing up everytime I move. The V8 figures themselves aren't even loading in correctly now.
That's the Iray preview starting to redraw, it's noisy at first and then smooths out (as with rendering). It may be that the Skin Builder materials end up being more complex than the defaults and so take longer to covnerge; it may also be that the preview is not using the GPU or is droppong to CPU for some reason.
its also possible your draw settings have changed, from your screenshot it looks like you are at a reduced manipultaion resolution.
if you don't have the draw settings pane open already you can find it windows>panes(tabs)
with nvidia iray as the draw mode select drawing and check your manipulation resolution
Yeah, Iray preview was enabled, fixed it, thanks.
