Hairs not visible!
So Im using these Hairs: https://www.daz3d.com/mrl-dforce-long-morphing-hair-for-genesis-8-females but somehow when I go in Iray preview or filament the hairs arent visible anymore. In texture shaded view they also dont look a bit weird but they are visible (Images attached). Cutout Opacity is set to 1, and the "visible in Render" option is also enabled. Can someone help :(
1354 x 845 - 236K
1340 x 844 - 462K
  • The final render will show it up, I think...
  • Oh thanks. I didnt try that! But is there any way I can make them visible in preview? Its a bit annoying to always start a render only to check if the hairs look good....
    Yes, but it will take some resources. Select the hair, then go into properties tab and look for the "tessellation" settings and up those one or two notchs till it displays
