Cannot find the path of Zbrush intallation
riomairiomai Posts: 44
edited September 2021 in Daz Studio Discussion
Hello. New windows installation and new daz and zbrush installation. I installed goz too but wen I'm trying to export the daz model, daz says "Sorry, cannot find Zbrush" "cannot find the path of Zbrush intallation"... but zbrush its installed. Can u help me please?
Thanks
Post edited by riomai on
    Well did you tell Daz Studio where to find it?
    https://www.daz3d.com/goz-for-daz-studio
    I don't know where it would show up in D/S, the bridges for Bryce and Hexagon appear on the Bridges tab under Preferences under Edit.
    Post edited by Catherine3678ab on
    I think this is the solution:  Thread post re GoZ.
    With the latest edition of D/S installed, one does not need to install the addition plug-in -- it should show under installed plugins as being available.
    If it doesn't, then install that plugin again. Something has to install the driver for the bridge ;-)
  • Thanks for answer Catherine. The Goz looks correctly installed and it appear in list on installed plugins... but when I try export a model in to zbrush it appear a window with words "Sorry, cannot find Zbrush" "cannot find the path of Zbrush intallation"
  • I assume ZBrush opens if run directly?
  • Also: are we talking full ZBrush and not ZBrushCore or CoreMini?  I also noticed some confusion on the Pix forums about this happening sometimes: only the full ZBrush program supports GoZ, not the other versions.
