Rotation Axis of Null is different type than Hip Node?
DiasporaDiaspora Posts: 552
When I select a G2F hip node and then Create>New Null>Copy Selected Item Hip
I notice that if I rotate all three axes of the Null node, the corresponding values will be very different than the corresponding values of the hip node rotated in a comparable manner. For specific reasons I want to be able to quickly rotate the hip node to match the rotation of a null node but because those rotation values don't appear to be interchangeable, I've hit a bit of a snag.
What can I do? Is there a quick and easy way of converting however a hip node might generate its rotation values to how a null might generate its values? Can I just set the null node to handle rotation the same way as a hip node would?
If I could do the latter, that would be all I need.
Post edited by Diaspora on
  • DiasporaDiaspora Posts: 552
    edited September 2021
    Solved!:
    I select the null
    Tools>Joint Editor
    and then in the viewport I right click the null Rotation Order>YZX
    And now the rotations align perfectly!
