M3 texture to any version of Genesis
in The Commons
I want to put a M3 skin texture to any of the Genesis Figures. Is there a utility plug in that can do this? Or a video tutorial ?
this thread has some options
https://www.daz3d.com/forums/discussion/520251/best-tool-for-uv-mapping-changing-goal-is-m3-v3-h3-a3-uv-to-genesis#latest
I use M3 obj as a UV set for V3 figure and V3 Legacy UV for G3F
Map transfer : M3 -> V3 -> G3F -> G3M
If you can find Universal Texture Convertor + UTC Bundle Pack, it can convert M3 to M4.
Legacy UVs don't enable you to use map transfer to make a G3F map from a V3 one, only to use the V3 map on G3F with the geografts.
Except if you export/import the figure as an OBJ
I use this OBJ with Map Transfer tool
https://www.daz3d.com/forums/discussion/302076/genesis-8-uv-for-legacy-uvs-geograft-done#latest
Thanks for that link Noah, I will pass it on to Jonstark in the thread I linked
