Set a Camera's default?
ScavengerScavenger Posts: 2,677
Is there a way to set what the default view of a camera (one you add to the scene) is?
So that you can like set up your camera frame the scene as you want, Do whatver to make that setting the "default", then say zoom in with the camera etc, then press the default button on the screen and have the camera snap back to where you wanted it to?
389 x 265 - 18K
  • Richard HaseltineRichard Haseltine Posts: 111,996
    Not for the restore button, but you can use Edit>Object>Memorise>Memorise Node(s) with the camera selected, then use Edit>Object>Restore>Restore Node(s) to reset it. Restore has a default short cut, cmd(Mac)/ctrl(Win)-e
