problems with dragon rider hair! [solved]
gabugabu Posts: 303
edited February 2015 in The Commons
It looks OK in the view port but when I render it goes a solid black with no transparency showing.
What am I doing wrong?
772 x 810 - 46K
Post edited by gabu on
  • SimonJMSimonJM Posts: 6,100
    Which render engine?
  • gabugabu Posts: 303
    3Delight using AMR's render pref script 'average quality' which is what I usually use with no problems
  • Richard HaseltineRichard Haseltine Posts: 111,399
    If you render then go to Help>Troubleshooting>View log and scroll to the end, are there any errors relating to image processing (TDLMake) or loading? Or to shaders?
    these are the relevant messages:
    Rendering Image
    WARNING: UberEnvironment2 1: The light 'Color' must be mapped in order to use 'Directional Shadows'; using Soft Shadows.
    3Delight message #43 (Severity 1): R2001: object 'shapematerial_Eyelashes_4979_12a0' (displacement 'DAZ/Uber/displacement/omDispStandard', surface 'DAZ/Uber/surface/omUberSurface') exceeded its displacement bound by 0%
    3Delight message #43 (Severity 0): R2093: object 'shapematerial_Hips_4974_12a0' (displacement 'DAZ/Uber/displacement/omDispStandard', surface 'DAZ/Uber/surface/omUberSurface') used only 21% of its displacement bound
    3Delight message #43 (Severity 0): R2093: object 'shapematerial_Forearms_4977_12a0' (displacement 'DAZ/Uber/displacement/omDispStandard', surface 'DAZ/Uber/surface/omUberSurface') used only 30% of its displacement bound
    3Delight message #43 (Severity 0): R2093: object 'shapematerial_Torso_4975_12a0' (displacement 'DAZ/Uber/displacement/omDispStandard', surface 'DAZ/Uber/surface/omUberSurface') used only 22% of its displacement bound
    3Delight message #43 (Severity 0): R2093: object 'shapematerial_Ears_4970_12a0' (displacement 'DAZ/Uber/displacement/omDispStandard', surface 'DAZ/Uber/surface/omUberSurface') used only 0% of its displacement bound
    3Delight message #43 (Severity 0): R2093: object 'shapematerial_Fingernails_4968_12a0' (displacement 'DAZ/Uber/displacement/omDispStandard', surface 'DAZ/Uber/surface/omUberSurface') used only 0% of its displacement bound
    3Delight message #43 (Severity 0): R2093: object 'shapematerial_Head_4969_12a0' (displacement 'DAZ/Uber/displacement/omDispStandard', surface 'DAZ/Uber/surface/omUberSurface') used only 0% of its displacement bound
    3Delight message #43 (Severity 0): R2093: object 'shapematerial_Nipples_4976_12a0' (displacement 'DAZ/Uber/displacement/omDispStandard', surface 'DAZ/Uber/surface/omUberSurface') used only 0% of its displacement bound
    3Delight message #43 (Severity 0): R2093: object 'shapematerial_Feet_4978_12a0' (displacement 'DAZ/Uber/displacement/omDispStandard', surface 'DAZ/Uber/surface/omUberSurface') used only 14% of its displacement bound
    3Delight message #43 (Severity 0): R2093: object 'shapematerial_Shoulders_4972_12a0' (displacement 'DAZ/Uber/displacement/omDispStandard', surface 'DAZ/Uber/surface/omUberSurface') used only 30% of its displacement bound
    3Delight message #43 (Severity 0): R2093: object 'shapematerial_Hands_4971_12a0' (displacement 'DAZ/Uber/displacement/omDispStandard', surface 'DAZ/Uber/surface/omUberSurface') used only 23% of its displacement bound
    3Delight message #43 (Severity 0): R2093: object 'shapematerial_Legs_4956_12a0' (displacement 'DAZ/Uber/displacement/omDispStandard', surface 'DAZ/Uber/surface/omUberSurface') used only 0% of its displacement bound
    3Delight message #43 (Severity 0): R2093: object 'shapematerial_Toenails_4966_12a0' (displacement 'DAZ/Uber/displacement/omDispStandard', surface 'DAZ/Uber/surface/omUberSurface') used only 0% of its displacement bound
    3Delight message #43 (Severity 0): R2093: object 'shapematerial_Neck_4973_12a0' (displacement 'DAZ/Uber/displacement/omDispStandard', surface 'DAZ/Uber/surface/omUberSurface') used only 17% of its displacement bound
    Saved image: C:\Users\ss\AppData\Roaming\DAZ 3D\Studio4\temp\render\r.png
    Finished Rendering
    it looks like that first warning might be the problem?
  • KeryaKerya Posts: 10,943
    Nice character! May I ask who he is?
    I am not usually using UberEnvironment ... walks off to try ...
    Works for me ...
    1094 x 845 - 543K
    He is Sulaiman available here at DAZ
    Strange that the hair seems to work for you. I will try setting him up from scratch with a fresh scene and see if that makes any difference. There coiuld be something hanging over from the last time I used it.
    Or just apply the material to the hair again?
    I used the DB_Hair_Mat (not the DB_Hair_Black_Mat ... but it shouldn't make a difference)
    Off to wishlist Sulaiman ...
    Ah!!!!!
    Everything is OK with a clean starting scene with a very basic light setup.
    The light setup I tend to use as standard comes from the SI Bandit Outfit. When I replace the basic lights with one of those sets the rendering is now OK.
    It looks like some bad settings might have accumulated from frequent use.
    Good luck with Sulaiman, he is a nice guy to know.
    I think I have solved it.
    The problem comes in when you do a complete load all.
    Reloading the hair mat fixes the problem.
    luv the beardie beads :)
  • kenwmay_bab7cfcd5fkenwmay_bab7cfcd5f Posts: 68
    edited October 2015
    This is what I get. I'll give it a try. Thanks.
    1270 x 663 - 121K
    Post edited by kenwmay_bab7cfcd5f on
