seamless texture for male gennesis 2 genitals
HogyoHogyo Posts: 59
Hi
I have made some genital textures for a few characteres who did not have any
Compared to their respective torsos tex, the colour is good.
But when I apply it with the surface utility it's a complete different thing.
I have also copied the torso colour settings to the hip and to genital then after copied and pasted my new texture without any better results.
Anyway there is always a strong difference along the seam
Anyone has a good trick for this?
thank you:-/
  • MarcCCTxMarcCCTx Posts: 947
    edited January 2015
    Maybe slosh's seam cover that came with Michael 4 for Genesis 2 Male would work. It's made to hide the difference between M4 genitals and G2Ms hip but I don't see why it couldn't hide the "scar".
    Edit: No, that doesn't work, the seam is much higher on G2M.
    By the way: the copy paste method does not change the shader used. I notice that a lot of the skins use Uber Surface shader but the default shader for the gens is DAZ Studio default. You might try applying a gens shader that matches the skin you're using before pasting the texture in.
    Post edited by MarcCCTx on
  • HogyoHogyo Posts: 59
    Thank you for this try!:smirk:
