what does the defaults button do in the render settings?
StratDragonStratDragon Posts: 3,290
edited September 2021 in Daz Studio Discussion
what does the defaults button do in the render settings? I'll make slight changes in the dials outside of the default settings, click defaults button and everything stays where it was.
Post edited by StratDragon on
  • IceCrMnIceCrMn Posts: 2,334
    I was just trying this out.
    It does reset some things but seems to be skipping tone mapping, General, and environment settings under iray.
    Under 3Delight it's skipping filter, progressive, and General.
    Is that what you are seeing?
    I didn't see it do anything I would think I would be seeing by definition of "default" for Iray; I haven't used 3Delight in ages,
    I can click initial parameters and see what the default is set to by checking them on dial at a time but if I change any of those values they don't go back to default values when I select the Default button.
    I'm using the .24 version of the public release. .30 seemed a bit shaky .
    If you change the settings under Render Mode; they don't change back when you press the Defaults button?
    they do until I get to the tone mapping settings and the environment settings. on a hunch I deleted those from the content list, created new ones and they default back. kinda weird but that's how it works.
