Daz Central is _hella_ broken. Daz Install Manager works properly.
Have been banging my head on this for weeks.
Issues with Daz Central:
  • After a certain amount of time after startup, the UI/Application just HANGS. CPU ramps up. No network activity. Unresponsive. Have to kill.
  • After attempting a download, will also hang.
  • Can't reliably recognize that Daz Studio IS installed.
  • Configuration for locations/paths is non-sensical.... and gets ignored or wiped every now and then....
  • Does not start up the Postgresql database!! No option to start up from Daz Central.
Daz Install Manager:
  • Simple and JUST WORKS.
  • Does not hang.
  • Setting/managing paths/destinations better... but still a MAJOR PITA if installing and using an external disk.
  • There is an option to "restart" the CMS... but it doesn't do anything. No errors. No status updates. Nothing. WTH.
Things to fix/address:
  • Either FIX the stability and performance issues on Daz Central or give it up and stop wasting time on it.
  • ASK for installation parent folders at install time.... don't just install files all over the dang place.
  • If the CMS/DB is down, actually offer help/instructions/commands/etc. to address the issue. NOWHERE do I see anything to re-init the database... point to the database, etc. Black Box Configurations = FAIL.
    Theoritically if DIM works Central should to as it is just a simplified version of DIM with a noob friendly UI but as you and others have reported it doesn't.  DAZ needs to get rid of Central and just put out instructions for using DIM.
  • frank0314frank0314 Posts: 15,102
    There is already quite thorough instructions on how to use DIM.
    As I said Central was meant to be noob friendly so any instructions also need to be noob friendly and the current ones are not.
