Export Daz objects to Terragen 4
Anybody who has experience in getting the materials to show up in Terragen when importing an .obj from Daz to Terragen?
No problems in getting it in there, but no materials?
Sorry if this isn't the  right forum for this post.
    is there no material editor in terragen to add textures to an object?
    Unfortunately not for the kind of stuff I want to bring into the program.
    I am confused, just had a look at the terragen 4 features and it says you can "apply external image maps to apply to any part of your scene, mixing them seamlessly with your procedural textures" so obviously you can load textures and apply them to the imported object. I also see it is node based, so you should be able to import the object, then just reimport and apply the textures for it if it is UVMapped.
    I'm new to Terragen so maybe I'll have to take a closer look at the procedures again - thanks for the advice :)
    I figured as much. Since most here don't use this app, you would probably have better luck at planetside's forums https://planetside.co.uk/forums/
