How do I add more detail to this face old?
lustfulrain
I'm kind of at a lose here. I didn't end up buying mabel in the end and its really been hitting me that I can't create an old terrfying looking witch without her. So this is what I have currently.
The iray result kind of looks a little off , Like plastic, I added lots of detail in the skin but still doesn't look right. Are there some skin surface settings or something I could mess to help with this.
What else does she need to give off an older more scary looking witch.
I think we need a few details about what you're doing at the moment, and what you want to do.
My initial thoughts would be (if G8F) to see if you could find a lined HD morph in your library. Failing that create a displacement map for lines and crank up the displacement. Make the lighting harsher & coming from one side. Use a pbr skin shader & see if you could scale up the frain onthe skin, making it deeper and larger. Just initial thoughts.
Regards,
Richard
