Pose control sliders not working properly
After loading the application and trying out the poses, I found that the smile, open smile, all expression sliders, and upper/lower eyelid sliders all acted like this. Both have the open smile slider all the way at 100, which should've looked like a regular smile, but instead, it makes both look like paralysis demons. Any help is very much appreciated, I have no idea what happened or how to fix it.
4128 x 1908 - 2M
Select your Genesis figure in the Scene Tree, go to the Properties pane, and select your Genesis figure there too. Then click on "Currently Used". That'll show you every morph that's being applied. Show us all of them so we can figure out which morph is being applied when it shouldn't be.
Window>Panes(Tabs)>Parameters is the one being referred to.
