genesis.dsf
sjjesso_78ca0e6d0csjjesso_78ca0e6d0c Posts: 79
I need this file in order to get Facegen Exporter to work. Every time I've tried to use it it says unable to find "DAZ Studio 4 default content path." I did a quick look and it turns out my copy requires genesis.dsf which I can't find in the directory. Any help would be appreciated as I don't want to spend another $135 dollars on an new copy of Exporter.
  • fixmypcmikefixmypcmike Posts: 19,731
    Install "Genesis Starter Essentials".
  • Richard HaseltineRichard Haseltine Posts: 111,721
    Is it looking for \Data\DAZ 3D\Genesis\Base\Genesis.dsf, or it is looking for \People\Genesis\Genesis.dsf? The former is in the Genesis Starter Essentials, so you should have it if you installed correctly; the latter is the old DS 4.0 file, it has been replaced by a .duf file, so the plug-in will need updating if it can't be configured to use the right file.
