How to change default path
larrygilmanlarrygilman Posts: 131
Hi All,
I tried saving a Scene to One drive and got the error that I could not. DAZ is trying to save to C:/Users/Larry/SkyDrive/... Well it can't and never will because there is no such place. Even when I open a Scene from OneDrive, DAZ still tries to save to SkyDrive. I have attached a picture that shows the error.
I looked in the places I know of but can't find where this default is coming from. Any help on where I need to go to change this??
628 x 273 - 135K
Post edited by larrygilman on
  • Richard HaseltineRichard Haseltine Posts: 112,059
    Window>Panes(Tabs)>Render Library.
    Open the pane's option menu (the lined button in the top corner of the pane, or right-click the tab) and select Render Directory Manager
    Click the + next to Base paths in the list
    Highlight the unwanted path
    Click Edit on the left and select the correct folder.
  • larrygilmanlarrygilman Posts: 131
    I thank you very much for the fast answer I found no reference to SkyDrive. But a setup a new base path to OneDrive. The only problem I have now is I cant find the new base path. The original is still there when I save, clicking the down arrow is not showing an alternate path. Can't I have more that one path??
    Thanks
    Yes, you can have as many paths as you like.
