Wardrobe Problems
verniceg18verniceg18 Posts: 3
Hello! I'm having problems applying wardrobes to several of my figures. For example: After loading Micheal 3, I've attempted to load clothing specifically for that figure without success. When I purchase the clothing the only thing listed was it was for Michael 3 with nothing else needed.
I've tried both double clicking and dragging, but nothing happens. Any ideas?
Thanks in advance,
Vernice
    We would need a little more information than that, like which clothing set is it
  • Richard HaseltineRichard Haseltine Posts: 111,399
    One thing to check is that you are loading the clothes (probably in Poser Formats>My DAZ 3D Library>Figures>some folder in the Content Library pane) and not material settings (Poser Formats>My DAZ 3D Library>Pose>Some folder), where My DAZ 3D LIbrary would be the content directory you installed to.
  • verniceg18verniceg18 Posts: 3
    Hi Chohole, the clothing is "The Pharoh for M3" and the M3 figure.
    Hi Richard, I'll check the paths.
    Thanks People
    edited January 2015
    Thanks People
    Ah right, so do you also have http://www.daz3d.com/pharaohs-of-the-sun-for-m3 as http://www.daz3d.com/the-pharaoh-for-m3 is an additional texture set for the first set I have linked to, and it does say
    Pharaohs of the Sun for M3
    M3 Fantasy Collar Set
    Which are both PC items so only $1.99 as you are a PC member.
    Post edited by Chohole on
    Hi Chohole, yes I do (should have mentioned that) and for some strange reason it still won't work. Haven't gotten home to check the paths yet.
  • kaotkblisskaotkbliss Posts: 2,918
    Since t's an add-on texture, did you load the original Pharaohs of the sun clothing, then select that clothing and double click the texture you want to use from the pharaoh?
