Iray Textures not showing up (Solved)
squirtsquirt Posts: 208
edited September 2021 in Daz Studio Discussion
Hello DAZ Gurus
I'm having a strange problem with DAZ 4.12 today.
When I load some hair onto a figure and attempt to change the color by double clicking the texture file her hair is not changing colors.  I exited DAZ and went into it again with the same results which kind of scares me.  Usually when you exit it clears the bugs but not this time. This is a new one on me.
Has anyone else encountered this before?  Know how to fix it?
Post edited by squirt on
  • It's a plain colour, not an overlay (like the Out Of Touch blending effects)? Have you tried rendering?
  • squirtsquirt Posts: 208
    It's a  .duf file so should change the color immediately.  Rendering makes no difference so the color wasn't changed.  It should become readily apparent in Iray Viewport mode but that shows the factory setting color that will not change.   I've made several renders with this hair at different colors so it's not a loading issue either.
    Also, if I try to delete the hair (with the hair selected)j it deletes the entire character as well.   Very strange.
    I fixed the problem.  Somehow I was in a strange pane that grouped everything together.  Had to get out of it in order to make things work again.  PROBLEM SOLVED.
