animate 2 problems
I just installed Daz Studio Pro 4.7 I am having problems with aniblocks in animate 2. IN the pervious version when I opened animate 2, you would see the fighting and dancing preset animations along the bottom. There is nothing there in this version. it is not hidden. there is nothing there. I did some research and found out I needed to install the aniblocks from a file. I followed the path for the file and I don't have that file. What should I do? Please help.
What file are you referring to?
The free Aniblocks are part of Genesis Starter Essentials, did you install that?
I don't think so, maybe that is my problem. I will install it and see if that Thank you for such a fast response.
I just reinstalled gofigures bellydance and monster walk
they have no ds files
so you cant see them in content library
My problem with the ani blocks not showing, was solved by the forum. I didn't have genesis 2 starter essentials installed. However, now I can't drag and drop the ani blocks into my animation. When I try to drag and drop a small circle with a slash through it shows up. Please help. Thank you
Thank you Jimmy C for solving my problem with the ani blocks. I didn't have Genesis Starter Esentials installed. Now I am having trouble dragging and dropping the ani blocks into my animation. A small circle appears with a slash through it when I try to drag and drop. Any ideas on this problem?
