How to apply a pose with couple
Hello everybody !
I bought any couple packgate, there is a pose with 2 character in there. This pose there is a scene which they hug with each other. But when i drag the pose to 2 character objects in my scene. Then it did not give the hug scene like the pose. How i have to do ?
For example : Link removed
How i drag a pose (with 2 character hug each other) into 2 character difference into an exact position (without change whatever, just need do something or click on something, it will help me to make this couple to hug in position correctly and match with each other like in the picture) ? :
Link removed
Post edited by truongphixulanh on
Which set? If they are Hierarchical pose presets then you would probably need one figure to be parented to the other, but most will just be regular poses with an A version and a B version (or some other way of distinguishing the figures) - select one figure, aply the A pose, select the other, apply the B pose.
I want to drag a pose to apply for 2 character difference in a scene, let make sure they hug each other like in this url
OK, I should have asked that you make sure it wasn't from an "adult" site like Renderotica. Looking at the product description, however, I think there are separate poses for the figues and for the Anatomical Elements - either named separately or in a folder to split by figure. If so you need to have the correct figure selected (easiest to do in the Scene pane) before applying each pose from a given set.
Thank you, i can do it, but if i want to save new pose which just created with 2 character difference in my scene, how can i do ? The first, i want to my 2 character walk or do something. When i want they hug each other, i can select the pose (just created) and i will get what i want.
