default resources for DAZ Studio missing
Hello,
TOday I enncountered a problem. When I load an asset in DAZ, like an environment. I get an error message saying that "default resources for DAZ Studio are missing", and that the asset could not work properly.
Indeed, an environment loaded is missing some textures. I checked the DIM, and the default resources for DAZ are shown as correctly installed (picture below)
Everything was working fine until yesterday. I could really use a bit of help about this.
Thanks in advance
3440 x 2088 - 379K
  • AscaniaAscania Posts: 1,856
    Then check if both D|S and DIM are pointed at the correct folders.
  • LeanaLeana Posts: 13,504
    edited September 2021
    Make sure you have the latest version installed, as it was updated to add the PBR shader when G8.1 was released.
    Post edited by Leana on
    And check that you haven't installed/updated the Default Resources also within DS (ie. with DAZ Connect)
  • Problem solved. It was indeed the default resources that were not updated.
    Thanks a lot for your answers
