Trying to make a head prop.
WillowRaven
I loaded v4 and applied the morph and shader I want. I have also blonde every body part but the head. Now how do I turn it into a prop of just the head?
If it is just a prop to stand around simply save it as a scene subset.
but wouldn't that save every body part, just hidden, and every time I need a spare head with no body and want to apply a fresh shader I'd have to reset the opacity of particular parts all over again, like the eyelashes?
You can export just the head then re-import it. You may be able to just save it as a subset and have it work. If not you will need to save it as an asset so that it correctly saves the data.
