Convert V4 UV Maps for G8F not working
sueya
in The Commons
https://www.daz3d.com/legacy-uvs-for-genesis-8-victoria-4 has stopped working for me. Should it be set up in a different directory from the equivalent product for converting Genesis 2 skins to G8F?
Sueya, in what way has it stopped working? It is set up, folderwise, in the same way as my other legacy products. Did you install it with DIM, or manually?
This is an example of what is going wrong
This is https://www.daz3d.com/helena-for-v4
It doesn't happen with all textures
I installed the product manually
Either the geografts haven't been loaded, or you haven't applied the V4 UVs to them. If they are loaded select the geografts in the Scene tab and apply the V4 UVs.
Looks like you are not using the legacy UVs product correctly. The parts in the image that are messed up are the geografts that are part of the product. You need to select all of those along with the figure and then apply the V4 uvs
