Can You LOCK a Whole Character ?
FauvistFauvist Posts: 2,291
edited September 2021 in The Commons
You can lock a paramter slider so that that parameter can't be accidentially changed, but is there some master lock to lock all the parameters of a character so the charracter can't be changed?
Thanks!
Post edited by Fauvist on
  • carrie58carrie58 Posts: 4,179
    You could save as a Character preset or just as a shape preset ,with the shape preset you have to load the base figure ,with the Character preset you don't
    Post edited by carrie58 on
  • IceCrMnIceCrMn Posts: 2,334
    Sure can.
    The same way you are locking one, you can lock them all at the same time.
    in the Scene Pane select your character.
    Right click it and select Select>Select Children
    On the Parameters Pane you should now see a very long list.
    Click one and then press CTRL+A to select all of them.
    Right click the word "Parameters" on the edge of the tab to open the context menu.
    Select "Lock>Lock Selected nodes" .
    You can do all 3 locks if you want, not sure if "Lock selected Nodes" will do what you need all by itself.
    If that doesn't work for what you need; you can always export the posed character(clothes and all) as a single obj then reimport it. At that point it won't have the ability to change shape or anything else because it will be little more than a statue that you can move around the room/scene.
