DAZ Studio 4.7, Navigation shortcuts now missing?
solarviewsolarview Posts: 289
Hi All,
Recently upgraded to version 4.7.
The Mac navigation shortcuts of using "Shift-Click" to pan and the "Option-Click" to rotate seems to be missing since the upgrade. Has this shortcut been eliminated? Or is there maybe an "Enable/Disable" button for this that might have gotten reset with the upgrade?
I was on version 4.5 previously.
Tech Info: i5 core 3.2 Ghz iMac running 16 GB Ram on Yosemite 10.10.
Thanks for your input.
- Sol
  • Richard HaseltineRichard Haseltine Posts: 112,003
    Try reloading your layout, from Window>Workspace>Select Layout. If that doesn't help you can restore the options in Window>Workspace>Customise - look at the View Controls area at the bottom of the dialogue, set the operation you want to set a modifier for, double-click the box for the combination and then press the keys and click the mouse as desired.
  • solarviewsolarview Posts: 289
    edited January 2015
    Perfect! Thanks, Richard. :-)
    That was what I was looking for. I guess that was an update, with 4.7??
    Been using that as a basic navigation tool forever. And pretty sure that I didnt set it up that way in my early days.
    Either way thanks for the heads-up on the location on those customization settings. The little orbiting ball works good enough I guess, but work much faster with the keyboard shortcuts. Much appreciated, man.
    - Sol
    Post edited by solarview on
