Character opacity when adding wardrobe
rshellmanrshellman Posts: 9
I am seeing an interesting effect in 4.7 that I have not noticed in previous builds.
In some cases, If I add a character and do a test render it works fine. When I add hair, it works fine. When I add clothes, the hair and clothes render correctly, but the character renders at about 50% opacity.
If I remove the wardrobe, the character renders correctly.
Steps to reproduce:
1. New Scene
2. Add V6
3. Add hair... I used Crazy locks here
4. Add Wardrobe. I used Casual Denim 2 Here
Any ideas welcome.
649 x 406 - 149K
  • SimonJMSimonJM Posts: 6,108
    Yes, me too! I presume that if you remove the clothing item things go back to normal?
  • rshellmanrshellman Posts: 9
    Yes, If I remove the clothing, the character and hair render correctly.
    edited January 2015
    I mentioned this effect in a post a while back but no-one else seemed to be getting it. I've had it chime in a couple of times, one was down to setting collision/smoothing on a facial scar.
    Post edited by SimonJM on
    Yes, Looks like my issue is a duplicate of the one you ased about previously, although using other outfits.
  • Cris PalominoCris Palomino Posts: 13,053
    It would be good for each of you to report what is sounding like a bug at this point.
    reported #185267 Bug:Character rendered as transparent after adding clothing.
    Request #185281 "Figure goes transluscnt whe..." created
    Before I forget - a workround has been found for this - go to advanced tab in render settings and toggle the motion blur checkbox.
