How do I export viewport custom style to other computers
I have four machines running DS and want to clone the viewport custom style to all of them.
I cannot find any built in option to export viewport styles. How can I copy my settings so the works space layout is identical on every machine?
No luck finding in seach.
You'll need to copy several files from the primary system to the others.
First, be sure to save your current layout as a custom layout. Window>workspace>save layout as... (F4 is the default shortcut).
Next, copy files.
the files you'll need to copy over are located in the c:\users\[name]\Appdata\Roaming\Daz 3D\Studio4
This file location is hidden by default, so you may need to go into the File properties options in control panel and enable "show Hidden Folders\files"
If you've saved a Custom layout, you should only need to copy the "User layouts" folder, then in DS switch to that layout.
If you haven't saved a custom layout, you'll need to copy the following files
Actions.dsx
Customactions.dsx
layout.dsx and dsa
menus.dsx
toolbars.dsx
If i've missed somthing, i'm sure somebody else will correct me.
You don't need to unhide anything nor change any settings to get there. Just point your browser to this folder: "%APPDATA%\DAZ 3D\Studio64" (without the "" of course), then follow the instructions shared by DrunkMonkey.
If you need to get into appdata\roaming you can use %APPDATA%, if you need appdata\local then use %LOCALAPPDATA%.
