Need Equestrain out fit for g8f
I found an amazing Equestrian outfit for G3F https://www.daz3d.com/equestrian-uniform-for-genesis-3-female-s but I can't find one for G8F. I don't want to go through the auto-fit stuff everytime I put it on g8.
Can someone recomend something that looks as good for G8f or is their a way to save the auto-fit stuff so that I can apply the outfit without doing menu stuff each time?
  • HylasHylas Posts: 5,328
    I think if you save the auto-fitted garments as scene subsets the auto-fit window won't show up again.
  • Ghosty12Ghosty12 Posts: 2,093
    What you can do and you only have to do it once.. Is to autofit the clothing to G8 as per usual, then for each clothing item go to File / Save As / Support Asset / Figure/Prop assets name and save where you want them to go.. When you hit save a popup like the image you see below will appear, fill in the relevant details and click accept.. Doing this way can be a bit tedious but it does make sure that the clothing will fit properly, and you won't get the autofit popup everytime..
    352 x 532 - 40K
    Thanks that is a good option
    You also don't have to auto-fit and force convert it to G8. You can quite easily convert G3 to G8 in just a couple clicks and then save them out as figure/prop assets.
    Yep, going from G3 to G8 I wouldn't autofit it anyway, just change the scene identifier and then save. It's what the clothes converter does.
    You would still need to pose the G3 clothes into the G8 base pose, bake the joint rotations, and then transfer the rigging. The clothing converters just automate those steps.
