Issue with tutorials
Hey guys, i've got a problem with sci-fi warrior tutorial. When it asks to set the Y Translate property, it just says "Follow the arrows through the Parameters Pane and set", nothing more. I looks like the window is too small for the rest of the text. I could try to do it myself, but the range of values in this case is very, very big. So, anyone could say the values or how to correct this problem with the text?
The value for 'Y' is 335
The value for 'Z' is 175
Then it goes to X Rotate = 150, Y to 80, and Z to -180 (note the minus)
Spread angle 35 degrees, Raytraced Shadows etc.
I don't know why you can't see these screens, you may be using a different layout? Have you customised anything? What is your screen resolution?
Thanks for your attention, that saved me!
Well, i'm using Hollywood Blvd. The only windows 'cut' are the second and third from both parameter settings, the other ones are normal.
