Is it possible to have clothing ignore certain body parts when posing?
I have a character that is sitting cross legged while levitating wearing a long coat.
Naturally the coat will follow the characters legs which normally would be great and all but for a character floating it doesn't look right.
Is it possible to somehow tick off some posing/shaping option that will have the coat ignore the leg posing?
I managed a work around by duplicating the character and coat then power posing their legs down then hiding the dupes but i figured id ask as there seems like there should be an easier way?
  • Can you dforce the lower part of the coat so that it hangs down?
  • SchaakaSchaaka Posts: 165
    That was something i tried but after siming it for a few percents i didnt see it change movement so i gave up assuming it wasnt a dforce object..
    but now that i say that, i can make it one.. huh, gona have to try it
  • Well, you could edit the weight maps to remove all the influnces of the leg bones (they'd get assigned to the hip instead), if anti-posing the coats bones doesn't work.
    Sorry for late reply, how does one begin to do this? If this is what i think it does, it might be exactly what i was looking for
  • Switch to the Node Weightmap brish tool, select the garment, right-click>Geometry Selectio>Select All, select a bone you don't want to affect the garment, select its weight map (General Weights for Genesis 8), right-click>Weight Editing>Fill selected, enter 0. Repeat for the other bones.
