Source Item Shape to Current or morph?
vintorixvintorix Posts: 220
For my own private use I have made two Genesis 2 clones for facilitating transferring cloth made in Marvelous Designer to Daz Studio. One for G2M and one for G2F, using the default MD male and female figure respectively. In DS I morph the G2 figure into the MD counterpart, rig it and dial back the morph. And the cloth comes along. Good, but I have two questions. Both male and female conversion works, but one only if I set the Source Item Shape to Current the other only if I set the Source Item Shape to Morph (and pick the right morph from the popup list). Why is that? There is no consistency. My other question is this. When I load the G2M figure the Michael 6 morph is always dialed up and I have to dial it down, why is that? That makes me unsure, how can I be sure no other morph are unintentional set?
  • fixmypcmikefixmypcmike Posts: 19,718
    Starting from the second part, load G2M, go to the Parameters pane, and see what shows under Currently Used. I suspect that's why you're getting the different behavior.
  • vintorixvintorix Posts: 220
    edited January 2015
    Thank you! It was a second, old version of the morph lying around. Get rid of that fixed the problem all thought it was dialed to zero.
    Post edited by vintorix on
