need to cut open Vicky's head ...
WillowRavenWillowRaven Posts: 3,787
I seem to recall seeing a freebie somewhere that removes the top portion of either v4 or m4’s head, to expose the brain. Any one know what I’m talking about?
Even if not a freebie, any link will help.
Thanks
  • Charles WestCharles West Posts: 123
    sounds like a map for a transparency is needed to fix up what you need
  • Charlie JudgeCharlie Judge Posts: 13,667
    Not V4 or M4 but there is this human head with brain exposed over at Turbosquid. Also its very pricey and not free:
    http://www.turbosquid.com/3d-models/skull-brain-3d-lwo/569043
    Charlie
  • LeatherGryphonLeatherGryphon Posts: 12,552
    Transparency map sounds like it would work.
    But don't expect to find anything inside. 8-O
    LOL. Are you saying Vicky is an airhead?
    Seriously though, if you decide to go the transmap route, this brain should fit in V4 or M4:
    http://www.daz3d.com/daz-brain
    Charlie
  • DraagonStormDraagonStorm Posts: 748
    http://www.daz3d.com/daz-brain which I'm seeing on sale right now. And a transparency map to open up the top of V4 head
    500 x 650 - 100K
  • WillowRavenWillowRaven Posts: 3,787
    Actually, That looks good, though I prefer the realness of the TA model, but reuse to pay the price.
    Where would I get a transmap like that, Draagon?
    I just used an image with a transparent background and a black circle in the middle.
    Went to the Opacity map for V4 face, Openned up Layered Image Editing. Added the face texture for a guide, Added the image with the black circle.
    Move the circle around until it's over the part you want to be transparent. Then go to the first layer, remove the face texture and set the background color to white, and save it...
  • TJohnTJohn Posts: 11,448
    Is someone writing a Hannibal Lector sequel?
    huh?
    Screenshots, maybe?
    Cool ... but no. It's for ad add campaign. Sorta like the brain workout graphics ... info going in and out ...
    huh?
    Screenshots, maybe?
    908 x 665 - 63K
    909 x 667 - 79K
    Huh ... I hadn't realized the map for her head was so big, lol. Thanks :D
  • StezzaStezza Posts: 9,291
    as mentioned, trans maps are easy to use/make in your favourite paint program..
    I also used the brain available at ShareCG..
    Only took around 10 minutes to give M4 some head space ;-)
    Used Carrara but should be same for DS
    640 x 480 - 95K
