Josephine 8
Hi,
Not sure where to post this, but...
I've just bought Josephine 8 figure, but when I install her using Daz Central, I get no body or head appear in my library.
Under characters, I have full materials directory, but of course the default G8 body and face are not changed.
What have I done wrong?
Thanks,
Chrissy
  • The Daz Name 8s do not usually have shaping presets - they have materials, and a character preset that will apply both shape and materials, but to set the shape alone you need to use the property sliders - go to the Shaping or Parameters panes, select the All group at the top (of the Editor tab in Shaping) and type josep in the filter box.
  • Saxa -- SDSaxa -- SD Posts: 882
    Go up one folder to characters and select that.   Josephine is there with all the others.  In sub-folder Josephine itself are just mats.  Pretty common with DAZ to find figure in higher root folder.  Categorizing means you can move stuff where you want, assuming you to take the time.
  • Thank you Richard, that's a great help - I've found them now.
    Saxa, that's what was puzzling me - the actual Josephine folder is empty - no shapers.
    Chrissy
    xxx
