What are the best Rendersettings for Daz Studio 4.7
PetraPetra Posts: 1,157
I am new to Daz Studio , well, I have used DS for years before I moved to Poser, but I am back since I adore Genesis.
I am not sure what would be the best Rendersettings in DS.
For example, by default the Shading Rate is 1 , I changed it to 0.20 as I have in Poser.
Not sure about all the other Settings so.
In the Rendersettings under * Sampling * what would be the BEST settings.
The Shadow Samples are by default 16, would it be better quality to set it to 32 or higher.
Pixel Samples X & Y are be default 4, I have changed them to 7
Max raytrace Depth I changed to 6.
I am really at this point not sure what will give me the best Render Quality.
Thank you for helping.
Petra
  • Richard HaseltineRichard Haseltine Posts: 111,363
    A lot of the settings depend on what you are rendering. Shading rate is certainly a quality slider, so knocking that down to .2 should have helped enormously. Shadow samples need to rise only if you are suing soft shadows - otherwise you are slowing the render down for no gain. The same is true for bounces, if you don't have multiple reflective or refractive surfaces interacting then there's no need to raise the value. There are several threads discussing what the settings are, and when to adjust them, and Adam has a set of presets here http://www.daz3d.com/forums/discussion/16085/
  • PetraPetra Posts: 1,157
    Thank you very much, this was so helpful:)
    Petra
