Hand Not Going Through Sleeve
gideonsprattgideonspratt Posts: 3
edited August 2021 in The Commons
Hello everyone,
I'm having a problem with a hand not going through the sleeve. The rest of the arm is inside it.
When I try to move or rotate just the 'Right Hand' section of the clothing it just rotates around the wrist but the hand never goes inside.
It works perfectly on the character's left hand. Does anyone know how to fix this?
Many thanks.
807 x 555 - 515K
614 x 449 - 396K
Post edited by gideonspratt on
  • Which outfit? Which figure? Is it the figure the outfit was made for?
    Sorry, I should've put that in the original post.
    The outfit is the Sweet Girl Outfit for Genesis 8 and 8.1 Females and I am using the Genesis 8 Female figure.
  • FSMCDesignsFSMCDesigns Posts: 12,858
    I don't have that one, but in the promo images it seems to fit fine. maybe try another scene with another G8 and a default pose and see if it works. If so it's probably a pose or dforce issue and you can trouble shoot from there.
  • felisfelis Posts: 6,628
    Don't have it either.
    But are you simulating it?
    My assumption would be best to start from default pose.
  • Thanks for the help everyone.
    It's very strange. If I zero the entire figure it works perfectly but if I only zero the right arm which is where the problem seems to be it makes no difference.
    I guess there's just something wrong with the pose I started off with.
  • frank0314frank0314 Posts: 15,116
    Does the pack come with any poses that you can test it on?
    Unfortunately not, but I've tested it out with a few other poses and I've determined it's something to do with the poses that come with the bike I'm using.
    I started her out in the zero pose and manually put her on the bike and the whole problem is solved. Thanks again everyone.
    1463 x 843 - 2M
    One thing you can try in the future, is to use the pose from the bike or where ever and then save that pose as a pose preset. I have found that many times this makes the pose work correctly when is is applied by your saved file instead of the product pose.
    Glad you got it working.
  • PetraPetra Posts: 1,157
    I am having the same problem with the same outfit and I have tried so many different poses from different vendors and the problem with the right sleeve persists.
  • Hello, I am sorry for the problem you faced. There were some problems in the program that led to the disappearance of some files (PJCMs) from the product. I contacted them and the problem was fixed. Accept my apology and you can download the product again and it will work fine.
    edited February 2022
    I'm not sure if my problem comes from the same reason, but I just bought your product yesterday and when trying it, I noticed that none of the "Adjustments" morphs in the "Parameters" tab for the "Sweet Girl Sweatshirt" are working. Setting the "Expand All" slider to 300% (maximum allowed) changes nothing. Maybe there's some more parts of the code missing?
    I opened a ticket about it, too...
    UPDATE: problem got solved today (took only 2 days.. extremely fast solution yes) - all the sliders are now working
    Post edited by maikdecker on
