Fitting Dynamic clothing to figure and animating!
Harkonnen1969Harkonnen1969 Posts: 131
edited January 2015 in The Commons
I'm trying to add dynamic clothing to v4 and animating it, but I can't fit it to V4 and get the clothing to move with the figure!
I'm using the following item on V4!
http://www.daz3d.com/dynamic-1900s-maids-dress
Post edited by Harkonnen1969 on
  • Harkonnen1969Harkonnen1969 Posts: 131
    It move in the preview in animate2 but not in the render!
  • kurisu2112kurisu2112 Posts: 198
    I think you need to bake the animation to Studio keyframes.
    Right click in the area belowe the displayed animate timeline and select bake to Studio keyframes and then run an animated drape.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,506
    yes sadly dynamics do not work with aniblocks only keyframed animation so you either need animate2 to bake it or use an animated pose file
    Thanks for the replies, sort of got a result but had lots of poke through! Will try again and hopefully get better results!
    I'm only able to get it to work on the first block, it's really frustrating!
    I've made a little progress as I seem to get the dynamic clothing to work properly, but the character stops moving after only one block even though I put three blocks of forward (1cycle)!
    edited January 2015
    Unless you are baking to timeline they are not going to work
    otherwise try a series of keyframed poses maybe using puppeteer or BVHmocap like
    http://www.cgspeed.com/2014/06/interim-files-listing-part-3-daz.html?m=1
