Nvidia eliminated the default application setup of DAZ Studio from NVIDIA Control Panel?
crosswind
After updating the latest versions of Nvidia Driver, I found the default application setup of DAZ Studio disappeared from the application list in NVIDIA Control Panel. What does it mean? Nvidia will not officially support DAZ Studio? Or there's some compatability issue for DAZ in this so-called Production Branch Driver version?
The reason why I asked this question is that I ever installed previous releases of Production Branch Driver where there WERE default application setup for DAZ, however, I encountered Windows' Blue Screen from time to time when rendering or previewing. This' driven me crazy! I nearly tried all means but found no solution for that. Then after I installed the latest driver, it seemed the problem has gone but the above-metioned Setup has also gone. So I'm not sure if it is the root reason...
I attached a screenshot. I installed the driver by default with Chinese language but still you can see the application list. I found DAZ application nowhere in there...
