(Solved) Accelerator (&) for DzPushButton added to DzButtonGroup not showing underlined?
The docs indicate that for the text property of DzButton (inherited by DzPushButton):
An ampersand (&) in the String automatically creates an accelerator for it using the character that follows the ampersand, as the accelerator key.
so,
btn.text = "&OK";
produces: OK It works fine on its own.
However, when I add a DzPushButton to a DzButtonGroup and assign its text property, the ampersand shows up with the text, instead of underlining the accelerator character when the button is displayed: &OK
Am I missing something obvious?
BTW, I'm using
var btn = new DzPushButton(wBtnGroup);
btn.text = "&Something with an ampersand";
to create the buttons directly as children of the button group.
Thanks in advance...
Post edited by ghost_of_delete_key on
I've found the solution after a bit of a fishing expedition through the QT docs.
Somehow, creating the DzPushButton with a DzButtonGroup as parent breaks the buttonTextFormat property, as described in OP.
To fix the ampersand appearing (although the accelerator works), the proper flags must be explicitly reset.
https://doc.qt.io/archives/qt-4.8/qt.html#AlignmentFlag-enum and https://doc.qt.io/archives/qt-4.8/qt.html#TextFlag-enum together list the flags that must be OR-ed together to create the desired text display.
In this case, keeping the default center-alignment of text, and displaying the underline for the accelerator, needs
AlignHCenter,AlignVCenterandTextShowMnemonicto be assigned to the button's property.So:
works perfectly.
https://prnt.sc/1rp3scd
Hope this helps someone sometime.
