Automatically append parameters to render file name?
Is there any way to make DAZ automatically append parameters to the name of the file when it saves it?
When I'm trying to work out the best settings to use for a scene, I'll typically create multiple renders at different resolutions, from different cameras, etc, and give them names like "Main room camera02 640x480 IRAY" so I can keep track of the settings used and compare results. Is there any way to automate this, so I don't have to type in a new name each time (and risk putting the wrong info in)?
Not built-in, but a script could edit the filename and save if you assigned that the ctrl S shortcut in place of the normal save (or use a different trigger to leave the regular save alone).
There is this though it's not doing exactly what you ask for:
Super Save - https://www.daz3d.com/catalog/product/view/id/024292
