can i add an external ca content folder?
Mistara
do shaders presets have to go in the shaders tab?
i like to put shader presets in a subfolder of the prop.
Well, if by content folder you mean the content tab, then the you can manually add a runtime to that.
If you mean the Object Tab, then you can add a folder to that manually as well.
I don't know if Carrara will allow a subfolder with shaders in a folder in the Object Browser as I haven't tried that. My suspicion is that you will see the sub-folder but not the contents, as an object or scene is stored in a .car file and a shader alone is saved as a .cbr, so the extension is different, and Carrara may be programmed to only see .cbr files in the Shader Browser. Can't hurt to give it a shot to see....
didn't realize had different file ext.
thanks.
i don't know how to fix my misdirects, haz to keep starting over.
Misdirects?
