Content Management Services ERROR 0xFFFFFFD9 in OSX 9.5?????
cafedeliccafedelic Posts: 10
Help!
I recently installed 4.7 and everything seemed to be working smoothly. Then this morning there were no product images in the Smart Content thumbnails. I tried closing and restarting DCMS using the Apple Scripts in the the Content Management Services UTILITIES folder.
However, DCMS will not open. The VLOG reports the following error:
"Sun Jan 18 2015 04:02:03.754274 DAZ Content Management Service (4.8.1, Kernel 4.8.1 )
Licence license_emb_4422548148518942 is registered to DAZ3D.
Valid until 9999-12-31. Subscription valid until 2013-02-08.
Maximum number of connections: 5
Sun Jan 18 2015 04:02:05.759650 (TID 140735134454544): ERROR 0xFFFFFFD9: Cannot open 'master' database
Sun Jan 18 2015 04:02:05.782244 (TID 140735134454544): Server terminated"
Any thoughts on what's wrong and how to fix it?
  • Richard HaseltineRichard Haseltine Posts: 111,743
    So you are still using Valentina, you haven't switched to PostgreSQL? Valentina seems to be very prone to database corruption - hence the switch to PostgreSQL. If you don't customise your data, or if you do but you recently exported your user data, it may be simplest just to install PostgreSQL and then reimport your database - go to the Content Library pane, open the option menu by clicking the lined button int he top corner or right-clicking the tab, select Content DB Maintenance, check re-import metadata and click Accept twice.
