HD Expressions without the HD? (SOLVED)
3dOutlaw3dOutlaw Posts: 2,481
edited August 2021 in The Commons
When I dial in the HD Expressions, they are looking good, when I let go of the slider, it add a bunch of detail that I am not wanting.  Any way to get that pose without the detail? (bereft HD, bored HD, etc)
Post edited by 3dOutlaw on
  • FrinkkyFrinkky Posts: 388
    The HD expressions may contain a hidden property that applies the HD part - turn on Show Hidden Properties, use the text field to filter Currently Used for the expression in question (eg. using your examples, for Bereft HD, type in 'bereft'). If there's a separate HD component, dial it down to zero.
    Awesome, thanks for the tip!  yes  As an example, for AfraidHD, I found it was also turning on the hidden:  eJCMAfraid_HD_div2, which has all the detail.
    FOLLOW_UP QUESTION:  I am trying to save a Pose or Properties Preset that will only turn on the AfraidHD and not the eJCMAfraid_HD_div2?  Unfortunately, it is not showing up in the list of "check all modified only".  Is there any way I can do that?
  • JoeQuickJoeQuick Posts: 1,735
    The one morph triggersthe other, so i think you'd want to save both?  Might be the only way to save it without the other one triggering (you'd be saving it dialed out).
    Yea, I want to save AfraidHD at 100%, but eJCMAfraid_HD_div2 dialed to 0%.
    Typically, applying these to human characters, both makes sense.  I am using them for Anime style characters, all the lines and details make a mess of the face.  I can manually dial it out each and every time, but it would be easier if I could save a preset with it dialed out.
    Turn down Sub-D levels.
    Well, yea that seems to do it laugh  Sometimes it's an easy solution staring you right in the face!  Thanks @jestmart / all!
