Apply material to all?
There used to be an apply material to all. If I made a white hand I could select in the drop down apply to all parts of the model. Where is that?
Also the background if I want it transparent when I render where is that?
Thanks!
    What application and version are you using?
  • edited December 1969
    Poser 2012
  • linvanchenelinvanchene Posts: 1,386
    edited February 2015
    edited and removed by user
    Post edited by linvanchene on
    Thank you. I don't use DAZ, can anyone with poser answer these questions?
  • KhoryKhory Posts: 3,854
    You need to select the whole material setting you created then copy it. You will need to past it to each surface separately unless you have a script to apply it to all of them. Not sure where the script is sold sorry.
    They had a place in the drop down of the material editor where you could select a material or edit/make a material and "apply material to all" and it would apply it to everything. It doesn't have it anymore?
  • jorge dorlandojorge dorlando Posts: 1,159
    Since you're rendering in PNG format, it will transparent background ...
  • Richard HaseltineRichard Haseltine Posts: 111,165
    PoserPro2014 does - I don't have 2012 installed to check that. If you aren't seeing the option menu arrow at all check your layout doesn't have something covering it.
    I would like transparency in a rendered video. How do I do that?
    The film can be exported into frames PNG formats as well,
    after that, import the still renders in a video editor ...
    I have heard of a certain codec exporting animations poser with transparent background, but I have never found this ...
    No nothing is covered up...
    in the material room you would hold shift when applying, will apply to all material zones for that figure.
