Pudgy the Corgi crashed my DS ...
2»
  • I'm sure Pudgy will be fixed.  But if you absolutely NEED to render a shot before the fix is out but are still concerned about messing up the shader settings for AFTER it is out... just up the paging file size.
    It's slow, but it WILL render.
    Terrible, clumsy solution.  But if it only takes a week for the fix to come out... it gets the job done without messing around with downgraging settings.
  • gitika1gitika1 Posts: 948
    Actually, I reached out to the PA and was told that I would have to tweak settings.  While I have experienced DS crashes, it has never been because my pc doesn't have enough system ram.
    After comparing the dforce fur on https://www.daz3d.com/pufflet-the-bunny and https://www.daz3d.com/pudgy-the-corgi, ; I believe the PR Interpolation Segment Length should be 1.0, not .10.  Pufflet's fur has a length of 1.0 for both settings and load without issues.
    522 x 167 - 16K
  • regenesis0regenesis0 Posts: 3
    edited August 2021
    That fixed it for me too!
    *sets his paging file back to something sane*
    Post edited by regenesis0 on
  • RainRain Posts: 354
    Thanks for that!  It worked!  I'm using DS 4.11 on a seven year old MAC and it rendered in Iray quite fast.
  • ritzeratze said:
    Original Settings for Pudgy:
    PR Interpolation Segment Length: 0.1
    Additional PR Hairs Density (cm^2): 1500
    Render below with settings:
    PR Interpolation Segment Length: 0.5
    Additional PR Hairs Density (cm^2): 400
    memory consumption reduced dramatically
    for VRAM and main memory
    thanks J Cade for the great tip!
    Thank you so much for this! It helped so much!
